Troubleshooting Reinstall via LiveSuit
  1. Click and hold down the FEL button on the back of the MOD Duo (in tiny hole), while you power it on
  4. Download https://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
  5. Install the FEL mode Windows driver (see #Installing FEL mode USB driver section below)
  6. Run LiveSuit and deploy the MOD Duo LiveSuit image (see #Deploying LiveSuit image below)
  7. Wait for the Duo's restore mode to activate
  8. Download the Duo image from Factory Reset Images and copy it to the mass storage device (as usual for MOD updates)
  9. Wait until the installation finishes (the Duo will automatically reboot)
Continue to step 6.
Finalizing
