Troubleshooting Reinstall via LiveSuit
- Run LiveSuit and deploy the MOD Duo LiveSuit image (see #Deploying LiveSuit image below)
Continue to step 6.
1. Find the folder where the PhoenixSuit downloaded in step 3 was extracted. Double-click on the PhoenixSuit application file inside to open it. The application window will look like this:
3. Click on the 'Upgrade' button or replug the USB cable that connects the MOD Duo to your PC (without taking off the power cable).
Finalizing
