Troubleshooting Reinstall via LiveSuit
Revision as of 12:43, 15 March 2023 by FalkTX (talk | contribs) (Undo revision 13620 by FalkTX (talk))
  1. Click and hold down the FEL button on the back of the MOD Duo (in tiny hole), while you power it on
  4. Download https://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
  5. Install the FEL mode Windows driver (see #Installing FEL mode USB driver section below)
  6. Run LiveSuit and deploy the MOD Duo LiveSuit image (see #Deploying LiveSuit image below)
  7. Wait for the Duo's restore mode to activate
  8. Download the Duo image from Factory Reset Images and copy it to the mass storage device (as usual for MOD updates)
  9. Wait until the installation finishes (the Duo will automatically reboot)
3. Click on the 'Upgrade' button or replug the USB cable that connects the MOD Duo to your PC (without taking off the power cable).
Finalizing
