Dwarf User Guide
The MOD Dwarf when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
  • Use supplied adapter only
Concepts and Modes
USB Host port (USB port A)
MIDI I/O
For example:
Menu button
Display
Control Mode
To cycle between the main assignment pages, you can use footswitch A.
Navigation Mode
Tool Mode
Tempo
  • Off: below -40dB
  • Red: between -1dB and 0dB
