Troubleshooting
- 6 MOD Duo X screens freeze
- 7 Failed to connect to MOD Cloud
- 8 Using Firefox and 'noscript' add-on prevents loading of cloud pedalboards
- 9 Dealing with noise issues
- 10 Device loses USB connection when computer enters sleep mode
- 11 Issues updating the MOD Footswitch
If you are not able to connect to your MOD device using macOS, please make sure that your computer didn't enter sleep mode while you had your MOD device connected via USB.
References on Ground Loops:
