Troubleshooting
Can't connect to the Web GUI in macOS
If you are not able to connect to your MOD device using macOS, please make sure that your computer didn't enter sleep mode while you had your MOD device connected via USB. Learn more on "Device loses USB connection when computer enters sleep mode.
References on Ground Loops:
MOD Duo X screens freeze
Site LOCAL
Accept from LOCAL
Deny
Dealing with noise issues
Issues updating the MOD Footswitch
