Control Chain Releases
MOD Footswitch
| Date | Main features | |
| 0.4.1 | 2021/03/16 | Fix value change of addressings through web GUI |
| 0.4.0 | 2020/11/26 | Feedback, Coloured lists, Momentary toggle and Tap-Tempo |
| 0.3.0 | 2018/05/19 | Integrate self-test in the main firmware |
| 0.2.2 | 2017/08/16 | Fix update message conflict when multiple devices are connected |
| 0.2.1 | 2017/07/11 | Fix issue when connecting multiple FootEx at same time |
| 0.2.0 | 2017/06/28 | Add support to 2 different baud rate |
| 0.1.0 | 2017/06/26 | Update protocol version |
| 0.0.6 | 2017/05/31 | Fix trigger and options assignment |
| 0.0.5 | 2017/04/06 | Initial version |
How to update the MOD Footswitch firmware
You can update the firmware of your MOD Footswitch from the settings menu on the WebGUI.
In order to process the update Go to the MOD Settings on your WebGUI and selected the Device Updates menu.
Once in the Device Updates screen, go to the XF4 section and click on the "Update firmware" button if your MOD Footswitch is not running the latest firmware version.
Note:When you connect your MOD Footswitch to its host MOD device you can check the firmware version of your MOD Footswitch on the right display while it is booting.
Note:The steps below only work with a Windows machine
- Download the firmware version from above
- Hold the footswitch 1 while connecting the MOD Footswitch to the computer
- The MOD Footswitch should be recognized on the computer as a mass storage device
- Copy the download file into that storage
- Eject the storage device
- Disconnect the MOD Footswitch from the computer
- Connect the MOD Footswitch to your MOD device
- The MOD Footswitch should now be running the version of the firmware that you uploaded (check the right screen while the MOD Footswitch is booting.
