MOD Web GUI User Guide
Connect your MOD device to your Linux, Windows or MacOS device using the USB cable which you received with your device. The operating system should recognize your unit as a network device and configure it automatically. In some cases, if it does not work, it can help to turn the device off and on again, keeping the USB cable connected. If it still doesn't work, please check the troubleshooting page.
If you are connecting via Bluetooth, visit http://192.168.50.1.
Creating a pedalboard
MOD Duo
MOD Duo X
MOD Dwarf
  1. Pedalboard name
  2. Pedalboard actions bar
  3. Inputs
  4. Pedalboard constructor
  5. Outputs
  6. Plugins bar
} Be aware that on the interface:
Adding and connecting plugins
Adjusting plugins parameters
Assigning plugins parameters
Removing an assignment
DUOX AssigningPluginsParametersToActuators1.png DUOX AssigningPluginsParametersToActuators2.png
Other MOD devices
Advanced Settings
Saving / loading pedalboard snapshots
You have the possibility to save the combination of parameter adjustments as a pedalboard snapshot. In order to do so, turn on the pedalboard snapshot mode by clicking on SnapshotsButton.png. Find it on the pedalboard actions bar.
A single click on the pedalboard image or name will load it to the constructor. To delete a pedalboard click on its trash icon Trash on the right of the pedalboard name.
Installing new plugins
Sharing a pedalboard
If you select Separated mode each single port of each single controller that you have connected to your MOD device and have active on your MIDI ports list will appear with different MIDI input and output.
MOD DUO MOD DUO X MOD DWARF
On the left edge of the constructor area (section 3) of the MOD DUO Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input. On the left edge of the constructor area (section 3) of the MOD DUO X Web GUI there are 5 connectors: 2 audio inputs, 1 MIDI input, 2 CV inputs and 1 expression pedal input.
On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output. All those connectors represent the real inputs and outputs of your MOD DUO. On the right edge (section 5) there are 5 connectors: 2 audio outputs, 1 MIDI output and 2 CV outputs. All those connectors represent the real inputs and outputs of your MOD DUO X.
MOD DUO MOD DUO X
Advanced Settings
MOD DUO MOD DUO X
Device Updates
