Dwarf User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
- Use supplied adapter only
Concepts and Modes
USB Host port (USB port A)
MIDI I/O
For example:
- Knob: turn for precise value change, hold and turn for coarse value change;
- List: turn left to open list and select prev item, turn right to open list and select next item, click to open/close overlay, hold then turn then release to open the list then change the value then immediately close the list.
Menu button
To the left of the display, you can find the Menu button.
Display
Control Mode
To cycle between the main assignment pages, you can use footswitch A.
Tool Mode
Tempo
