Dwarf Device Settings
  • Headphone Output: setup the volume of your headphones (volume of headphones output)
  • Device Settings (1/2): setup the appearance of your device
  • Device Settings (2/2): setup the appearance of your device, tools, and USB behavior
  • Quick Items: define the Quick Items that appear when you push the Menu Button
(image of Quick items menu)
Audio Inputs
Notes:
Audio Outputs
Headphone Output
Sync
On this menu, you can define MIDI settings for your MOD Dwarf. This menu allows you to define the MIDI Program Change Channel used to change your pedalboards and snapshots if you define any.
Before saving you must:
  1. Navigate to System Settings and change values for Input, Output, and Sync an MIDI settings
400px
400px
The device settings on the MOD Dwarf are divided into two pages.
On the first page, you can make mainly visual adjustments like:
  • the Display Brightness
  • the Display Contrast
  • how Unassigned Actuators are represented
On the second page of Device Settings, you can also set some behavior settings for your MOD Dwarf like:
  • the Default Tool
  • what appears on the Control Header
  • the USB-B Mode
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Note: You can press the endless knob while turning to fine adjustments.
Default Tool
You can select between:
  • Tuner
  • Tempo
Control Header
USB-B Mode
  • Network (Default)
  • Net+MIDI
  • Net+MIDI (Windows)
Network (Default)
Net+MIDI
Net+MIDI (Windows)
Quick Items
In this menu, you can define and organize the three quick items that show up on your screen when you push the Menu Button.
Here is the list of all the settings that you can define for each of the three quick items:
  • Input 1 Gain
  • Input 2 Gain
  • Output 1 Gain
  • Output 2 Gain
  • Headphone Volume
  • Clock Source
  • Send Clock state (On/Off)
  • Display Brightness
  • Beats Per Minute
  • Beats Per Bar
