Dwarf Device Settings
(image of Quick items menu)
Audio Inputs
Notes:
Audio Outputs
Headphone Output
(replace with image bellow with image of Headphone Output menu on the Dwarf)
Sync
(replace with image bellow with image of Sync menu on the Dwarf)
(replace with image bellow with image of MIDI menu on the Dwarf)
On this menu, you can define MIDI settings for your MOD Dwarf. This menu allows you to define the MIDI Program Change Channel used to change your pedalboards and snapshots if you define any.
(replace with image bellow with image of User Profiles menu on the Dwarf)
To switch between users profile you simply need to turn the left most endless knob. This will allow you to swipe between all the user profiles. To validate the selection you should click the knob while the new User Profile shows us up to you.
(image showing this)
Before saving you must:
(image of device settings 2 pages on the Dwarf)
The device settings on the MOD Dwarf are divided into two pages.
On the first page, you can make mainly visual adjustments like:
- the Display Brightness
- the Display Contrast
- how Unassigned Actuators are represented
On the second page of Device Settings, you can also set some behaviour settings for your MOD Dwarf like:
- the Default Tool
- what appears on the Control Header
- the USB-B Mode
Note: You can press the endless knob while turning to fine adjustments.
Default Tool
You can select between:
- Tuner
- Tempo
Control Header
USB-B Mode
- Network (Default)
- Net+MIDI
- Net+MIDI (Windows)
Network (Default)
This mode will allow you to access the WebGUI in your favourite browser by navigating to http://moddwarf.local/ (or http://192.168.51.1).
Net+MIDI
This mode will allow you to access the WebGUI in your favourite browser by navigating to http://moddwarf.local/ (or http://192.168.51.1). This mode also allows your MOD Dwarf to receive and send MIDI messages over the USB port.
Net+MIDI (Windows)
Quick Items
In this menu, you can define and organize the three quick items that show up on your screen when you push the Menu Button.
Here is the list of all the settings that you can define for each of the three quick items:
- Input 1 Gain
- Input 2 Gain
- Output 1 Gain
- Output 2 Gain
- Headphone Volume
- Clock Source
- Send Clock state (On/Off)
- Display Brightness
- Beats Per Minute
- Beats Per Bar
(replace with an image of System Upgrade screen on the Dwarf)
