MOD DUO
A: line level input
- Sync & MIDI
B: instrument level input
- Sync & MIDI
C: mic level input
- Sync & MIDI
D: internal sound generation
- Sync & MIDI
A: line level input
- Sync & MIDI
- Sync & MIDI
C: mic level input
- Sync & MIDI
D: instrument level input
- Sync & MIDI
- Sync & MIDI
- Bluetooth
- Info
- System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
Pages Mode
Pot Calibration Mode
