MOD Web GUI User Guide
Creating a pedalboard
MOD DUO MOD DUO X
  1. Pedalboard name
  2. Pedalboard actions bar
  3. Inputs
  4. Pedalboard constructor
  5. Outputs
  6. Plugins bar
MOD DUO MOD DUO X
On the left edge of the constructor area (section 3) of the MOD DUO Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input. On the left edge of the constructor area (section 3) of the MOD DUO X Web GUI there are 5 connectors: 2 audio inputs, 1 MIDI input, 2 CV inputs and 1 expression pedal input.
On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output. All those connectors represent the real inputs and outputs of your MOD DUO. On the right edge (section 5) there are 5 connectors: 2 audio outputs, 1 MIDI output and 2 CV outputs. All those connectors represent the real inputs and outputs of your MOD DUO X.
This is a standard behaviour both for the MOD DUO and the DUO X
Adding and connecting plugins
Adjusting plugins parameters
Assigning plugins parameters
Removing an assignment
Making an assignment to a MOD DUO actuator
Making an assignment to a MOD DUO X actuator
On the MOD DUO X, you have a pagination system (learn more about it on Pagination and Switching Pages) that allows you to assign multiple parameters to each of the actuators (endless knobs, knobs and buttons).
Select on this window the actuator that you want to assign on the correspondent page.
DUOX AssigningPluginsParametersToActuators1.png DUOX AssigningPluginsParametersToActuators2.png
If you want to assign any type of parameter to an actuator of a MIDI Controller connected to your MOD device you must select the "MIDI" tab, press save and interact with the desired actuator (for example: push the button or turn the knob).
Other MOD devices
Advanced Settings
Here you can:
Saving / loading pedalboard snapshots
You have the possibility to save the combination of parameter adjustments as a pedalboard snapshot. In order to do so, turn on the pedalboard snapshot mode by clicking on the snapshot button SnapshotsButton.png, positioned on the pedalboard actions bar.
Another way to navigate the snapshots is using an external MIDI controller connected to your MOD device.
On the MOD Duo, you can also use the Footswitches to navigate through the pedalboards of a bank. In order to do it just active the option "Foot Nav" on teh Settings of your MOD Duo.
Installing new plugins
By default MOD devices come with many plugins installed, but you can install even more. The plugins available for download for MOD devices are created either by the MOD team, or by independent developers. To learn more about plugins please check the Advanced Information chapter.
Sharing a pedalboard
Another great feature that the MOD devices have is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard constructor and click on the share Share pedalboard button in the pedalboard actions bar. Fill in the sharing dialog and (optionally) record a sample by clicking on the red circle. After finishing the recording, you can listen to it, or record it again. When you are done, click on the Share button.
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI controllers. Your MOD device will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports Gui-midi-ports.png button.
If you select Separated mode each single port of each single controller that you have connected to your MOD device and have active on your MIDI ports list will appear with different MIDI input and output.
MOD DUO MOD DUO X
Advanced Settings
MOD DUO MOD DUO X
Device Updates
