MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Creating a pedalboard
- 2.1 New pedalboard
- 2.6 Saving a pedalboard
- 2.7 Organizing Banks
- 2.8 Installing new plugins
- 2.9 Sharing a pedalboard
- 3 Expanding Controls
- 4 True Bypass
- 5 CPU Usage
- 6 Settings
MOD DUO | MOD DUO X |
- Pedalboard name
- Pedalboard actions bar
- Pedalboard constructor
- Plugins bar
On the left edge of the assembler area (section 3) of the MOD DUO Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input. | On the left edge of the assembler area (section 3) of the MOD DUO X Web GUI there are 5 connectors: 2 audio inputs, 1 MIDI input, 2 CV inputs and 1 expression pedal input. |
On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output. All those connectors represent the real inputs and outputs of your MOD DUO. | On the right edge (section 5) there are 5 connectors: 2 audio outputs, 1 MIDI output and 2 CV outputs. All those connectors represent the real inputs and outputs of your MOD DUO X. |
This is a standard behaviour both for the MOD DUO and the DUO X
and delete
To create an assignment, first click on the fader icon , found on the bottom-right corner of each parameter box, to open the assignment dialog box. For the presets list you must click "Assign All" and you must have your list populated with more then one preset.
Removing an assignment
Making an assignment to a MOD DUO actuator
Making an assignment to a MOD DUO X actuator
On the MOD DUO X, you have a pagination system (learn more about it here and here) that allows you to assign multiple parameters to each of the actuators (endless knobs, knobs and buttons).
Select on this window the actuator that you want to assign.
If you want to assign any type of parameter to an actuator of an external MIDI Controller you much select the "MIDI" tab, press save and interact with the desired actuator (for example: push the button or turn the knob).
Other MOD devices
- Two squares will appear on the right side of the CV plugin that you've just loaded. Select and label the ones that you want to use.
- This way you just created an internal CV controller. Head back to the CV tab of the control you want to assign and now you will be able to see a dropdown menu with the labels that you just created on your CV plugins.
Advanced Settings
Here you can:
You have the possibility to save the combination of parameter adjustments as a pedalboard snapshot. In order to do so, turn on the pedalboard snapshot mode by clicking on the snapshot button , positioned on the pedalboard actions bar.
Another way to navigate the snapshots is using an external MIDI controller connected to your MOD device.
On the MOD Duo, you can also use the Footswitches to navigate through the pedalboards of a bank. In order to do it just active the option "Foot Nav" on teh Settings of your MOD Duo.
By default MOD devices come with many plugins installed, but you can install even more. The plugins available for download for MOD devices are created either by the MOD team, or by independent developers. To learn more about plugins please check the Advanced Information chapter.
Another great feature that the MOD devices have is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard constructor and click on the share button in the pedalboard actions bar. Fill in the sharing dialog and (optionally) record a sample by clicking on the red circle. After finishing the recording, you can listen to it, or record it again. When you are done, click on the Share button.
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI controllers. Your MOD device will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports button.
Preferences
