MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Creating a pedalboard
- 3 Expanding Controls
- 4 True Bypass
- 5 CPU Usage
- 6 Settings
MOD DUO | MOD DUO X |
- Pedalboard name
- Pedalboard actions bar
- Pedalboard assembler
- Plugins bar
On the left edge of the assembler area (section 3) of the MOD DUO Web GUI there are 3 connectors: 2 audio inputs and 1 MIDI input. | On the left edge of the assembler area (section 3) of the MOD DUO X Web GUI there are 5 connectors: 2 audio inputs, 1 MIDI input, 2 CV inputs and 1 expression pedal input. |
On the right edge (section 5) there are another 3 connectors: 2 audio outputs and 1 MIDI output. All those connectors represent the real inputs and outputs of your MOD DUO. | On the right edge (section 5) there are 5 connectors: 2 audio outputs, 1 MIDI output and 2 CV outputs. All those connectors represent the real inputs and outputs of your MOD DUO X. |
This is a standard behaviour both for the MOD DUO and the DUO X
Adding and connecting plugins
Adjusting plugins parameters
and delete
To create an assignment, first click on the fader icon , found on the bottom-right corner of each parameter box, to open the assignment dialog box.
- If you want to assign a parameter to one of the actuators on your MOD device select the tab "Device".
- If you want to assign a parameter to a MIDI controller that you have connected to your MOD device select the tab "MIDI".
- If you want to assign a parameter to a control chain device (like the MOD Footswitch or the Arduino Shield) select the tab "Control Chain".
- If you want to assign a parameter to one CV controller connected to your MOD device select the tab "CV".
On the MOD DUO, the knobs can hold multiple assignments but footswitches can only hold one.
On the MOD DUO X, you have a pagination system (learn more about it here and here) that allows you to assign multiple parameters to each of the actuators (endless knobs, knobs and buttons). To switch between these pages you should use the performance buttons on your DUO X.
TODO: Control Chain and CV
Trigger | Yes | No | Yes |
Here you can:
Installing new plugins
Sharing a pedalboard
Another great feature that the MOD devices have is allowing you to share and load pedalboards from the existing MOD online community. To share a pedalboard, go to the pedalboard assembler and click on the share button in the pedalboard actions bar. Fill in the sharing dialog and (optionally) record a sample by clicking on the red circle. After finishing the recording, you can listen to it, or record it again. When you are done, click on the Share button.
In addition to the classic MIDI ports you can also use the USB port to connect your MIDI controllers. Your MOD device will recognize your MIDI device when it is plugged in and add it to the MIDI ports list. Because a single MIDI device can have multiple ports, they are not visible in the assembler by default. To make them visible you will have to enable them first by clicking on the MIDI ports button.
Preferences
