Revision as of 13:01, 9 September 2020 by Joao.sensiguitar (talk | contribs) (→‎B:)
MOD DUO
TODO: Factory user Profiles MOD DUO
A:
  • Inputs
  • Outputs
  • Sync & MIDI
B:
  • Inputs
  • Outputs
  • Sync & MIDI
C:
  • Inputs
  • Outputs
  • Sync & MIDI
D:
  • Inputs
  • Outputs
  • Sync & MIDI
A: line level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
C: mic level input
  • Inputs
  • Outputs
  • Sync & MIDI
D: instrument level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Pages Mode
Pot Calibration Mode
IMAGE: PICTURE OF THE SCREEN
