A: line level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
C: mic level input
  • Inputs
    • This profile has the 'Stereo Link' function not active. The input 2 is with no gain and the input 1 with 70%. This is a gain level ideal to connect a mono microfone to your input 1.
  • Outputs
  • Sync & MIDI
D: instrument level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Pages Mode
Pot Calibration Mode
IMAGE: PICTURE OF THE SCREEN
