- System: Access system-wide settings and information such as inputs and outputs gains, Bluetooth configuration and more.
A: line level input
- Sync & MIDI
- Sync & MIDI
C: mic level input
- This profile has the 'Stereo Link' function not active. The input 2 is with no gain and the input 1 with 70%. This is a gain level ideal to connect a mono microfone to your input 1.
- Sync & MIDI
D: instrument level input
- Sync & MIDI
- Sync & MIDI
- Bluetooth
- Info
- System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
Pages Mode
Pot Calibration Mode
IMAGE: PICTURE OF THE SCREEN
Note: if you re-calibrate the knobs of your MOD Duo X only the range of the knob will be modified. It may be faster or slower reaching the maximum value.
