A: line level input
C: mic level input
D: instrument level input
  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Pages Mode
Pot Calibration Mode
IMAGE: PICTURE OF THE SCREEN
Note: if you re-calibrate the knobs of your MOD Duo X only the range of the knob will be modified. It may be faster or slower reaching the maximum value.
