- System: Access system-wide settings and information such as inputs and outputs gains, Bluetooth configuration and more.
- Sync & MIDI
- Bluetooth
- Info
- System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
Pages Mode
Pot Calibration Mode
IMAGE: PICTURE OF THE SCREEN
Note: if you re-calibrate the knobs of your MOD Duo X only the range of the knob will be modified. It may be faster or slower reaching the maximum value.
