With the 'Tempo & Transport' menu selected push the left endless knob to activate or deactivate the transport. In other works, this works as if you were pressing play on your DAW. On the right screen you can see and edit both the tempo (in bpm) and the time signature (beats per bar). The count is always done in quarter notes.
  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
TODO
Name: Shows the name of your device in the Bluetooth network.
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Pages Mode
Pot Calibration Mode
