  • Inputs
  • Outputs
  • Sync & MIDI
  • Bluetooth
  • Info
  • System Upgrade
PEDALBOARD NAV MIDI CHN
SHAPSHOT NAV MIDI CHAN
TODO
Name: Shows the name of your device in the Bluetooth network.
  • 0% (off)
  • 25%
  • 50%
  • 75%
  • 100%
Pages Mode
Pot Calibration Mode
