Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
Headphone/CV Output
You can daisy chain up to 8 Control Chain devices using a single cable from one Control Chain device to the other.
Finally, the MOD Duo X also supports "old-school" DIN-MIDI devices, simply hook up your DIN-MIDI device to the appropriate port on the back and enjoy!
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- Off: below -30dB
- Red: above -3dB
- 1st page: red
- 2nd page: yellow
- 3rd page: green
