Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
Headphone/CV Output
The MOD Duo X comes with its own approved power supply which outputs 12V, 2A over a center-positive barrel-type plug. In order to work, the MOD Duo X requires at least 12W, 1.5A although this can cause problems when you connect Control Chain devices or controllers. You also need to pay attention to the polarity of your plug, it must be central positive.
In summary, the power consumption of the MOD Duo X varies depending on the peripherals connected to the device. For example: Hooking up a USB-hub to the USB-A port, and then hooking up multiple MIDI controllers to the hub will change the power requirements. By using the provided power supply you are sure that you will never run out of juice.
You can daisy chain up to 8 Control Chain devices using a single cable from one Control Chain device to the other.
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- Off: below -30dB
- Red: above -3dB
- 1st page: red
- 2nd page: yellow
- 3rd page: green
