Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
You can connect an expression pedal or two control voltage inputs to this port. Define either if you are using it to connect an expression pedal or CV input in the device menu.
Headphone/CV Output
The headphone output on the MOD Duo X monitors output 1 and 2. It is possible to set the volume level of the headphone output through the device menu. On the MOD Duo X you can also use this port to get two control voltage outputs. For that you must select this option on the device menu.
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- Off: below -30dB
- Red: above -3dB
- 1st page: red
- 2nd page: yellow
- 3rd page: green
