Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
You can connect an expression pedal or two control voltage inputs to this port. Define either if you are using it to connect an expression pedal or CV input in the device menu.
Headphone/CV Output
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- Off: below -30dB
- Red: above -3dB
- 1st page: red
- 2nd page: yellow
- 3rd page: green
