Duo X User Guide
The MOD Duo X when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
You can connect an expression pedal or two control voltage inputs to this port. Define either if you are using it to connect an expression pedal or CV input in the device menu.
Headphone/CC jack
SPDIF out
Left endless knob actions
  • Hold the left knob to access and exit the Device Settings menu
Right endless knob actions
  • Turn it to control the master output volumes
  • Press and hold it again to exit master volume control
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
  • Off: below -30dB
  • Red: above -3dB
  • 1st page: red
  • 2nd page: yellow
  • 3rd page: green
