Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
You can connect an expression pedal or two control voltage inputs on MOD Duo X has two independent audio inputs, with configurable input gain for each input. You can set up the input gain through the device menu
Headphone/CC jack
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- Off: below -30dB
- Red: above -3dB
- 1st page: red
- 2nd page: yellow
- 3rd page: green
