Duo X User Guide
The MOD Duo X when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CV Input
Headphone/CC jack
SPDIF out
Left endless knob actions
  • Hold the left knob to access and exit the Device Settings menu
Right endless knob actions
  • Turn it to control the master output volumes
  • Press and hold it again to exit master volume control
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
  • Off: below -30dB
  • Red: above -3dB
  • 1st page: red
  • 2nd page: yellow
  • 3rd page: green
