Duo X User Guide
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CC Input
Headphone/CC jack
The headphone output on the MOD Duo monitors output 1 and 2. It is possible to set the volume level of the headphone output through the device menu.
SPDIF out
Left endless knob actions
Right endless knob actions
Performance buttons
Instant snapshots
Pagination
Left Display
Right Display
- Off: below -30dB
- Red: above -3dB
- 1st page: red
- 2nd page: yellow
- 3rd page: green
