Troubleshooting Reinstall Duo
Different MOD Duo models
A note on different models and old kernel
Since version 1.10, we changed the kernel used by the Duo, but this update only automatically applies to new unit models.
For the older models, we need to either do a special update step, or a full factory reset.
In both cases the disk contents (user data) is completely wiped out.
You can check which kernel version you are running by looking at the "System information" in the advanced settings.
Kernel release 5.4.38-rt21-modduo is the newer one, while 3.4.104-rt139-modduo is the older one.
The new kernel offers better performance and reliability, so you are still using the old one please update!
Special update for nand units
In order to make older MOD Duo units switch to the new kernel we can use a special update file.
This was created mainly for those users who are using Windows or are not comfortable with the command-line.
Please do not power off your unit once the procedure has started!
  1. Put the unit into recovery mode. See Releases if you need help on that.
  2. Download this special update file modduo-convert-nand_20200529.tar
  3. Install the tar file in the previous step, and wait until the unit boots itself again in restore mode (this might take a few minutes)
  4. Install a MOD factory reset image from the Factory Reset Images section.
  5. Wait until the MOD sets leds green and reboots itself
MOD Duo Factory Reset
For a factory reset under Windows, see Troubleshooting Reinstall via LiveSuit. (applies only to older MOD Duo units with nand flash)
  2. Hold it for 2 seconds, then release (The screens will freeze with the MOD logo and name)
  4. Download this file: http://download.moddevices.com/releases/modduo/tools/duo-nand-mainline-factory-reset.tar.gz and extract it
  5. Open a terminal and 'cd' to the directory where duo-nand-mainline-factory-reset.tar.gz was extracted, ie:
cd ~/Downloads/duo-nand-mainline-factory-reset
Now simply run:
./boot-fel-factory-reset.sh
If the above command fails with "USB FEL device not found", try a different usb port of the computer. It might not work with usb hubs or usb-type-c/thunderbolt adapters, so connecting directly to a USB port is preferred..
For non-64bit Linux or macOS systems, use the sunxi-fel binary from your distribution.
Continuing:
  1. After the script finishes, wait for around 1 minute and the MOD Duo will boot into recovery mode. (confirmed by LEDs turning blue. note that sometimes the display does not change)
  2. Install a MOD OS factory reset image.
  3. Wait for the installation to complete (the unit will restart automatically).
