Troubleshooting Reinstall via LiveSuit
- Download http://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
- Run LiveSuit and deploy the MOD Duo LiveSuit image (see #Deploying LiveSuit image below)
2. Download http://download.moddevices.com/releases/modduo/tools/modduo_livesuit_20200621.img
3. Click on the 'Upgrade' button or replug the USB cable that connects the MOD Duo to your PC (without taking off the power cable).
