Duo X User Guide
Revision as of 13:00, 13 September 2019 by Leogermani (talk | contribs) (→‎Actuators)
The MOD Duo X when powered up
AUDIO OUTPUTS WARNING !
POWER ADAPTER WARNING !
Expression/CC Input
Headphone/CC jack
The headphone output on the MOD Duo monitors output 1 and 2. It is possible to set the volume level of the headphone output through the device menu.
SPDIF out
Left endless knob actions
  • Hold the left knob to access and exit the device menu
Right endless knob actions
  • Turn it to control the master output volumes
  • Press and hold it again to exit master volume control
Performance buttons
Instant snapshots
Pagination
  • Off: below -30dB
  • Red: above -3dB
The MOD Duo X allows each input and output volume to be individually adjusted. Please refer to the Inputs and Outputs Device Settings section in the wiki for more information on that.
There is also a shortcut pressing and holding the right endless knob. This will turn this knob into the master output volume control. Press and hold it again to exit this mode.
After you have powered on and adjusted the volumes of your MOD Duo X, it is ready for playtime. The MOD Duo X comes with many pedalboards ready to be used. They are organized in banks and can be accessed via SETTINGS menu. Please refer to the Banks section on the Device Settings page for more information.
TODO -> add screenshots from the LCD displays and explain what each part of the screen represent
Note: The animation above does not show it properly, but Buttons and Endless knobs are also paginated.
  • 1st page: red
  • 2nd page: yellow
  • 3rd page: green
Pressing and hold the left endless knob will open the Device Settings menu. Access the Device Settings page to learn how to use it to Load Banks and Pedalboards, adjust volumes and MIDI Settings, manage User profiles and more.
After successfully connecting the MOD Duo X to your PC or Mac, open your favorite browser and navigate to http://modduo.local (or http://192.168.51.1).
