MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Bottom bar
- 3 Pedalboard builder
- 4 Pedalboard library
- 5 Banks
- 6 Plugin store
USB
- Power up the MOD Duo
- Open your favorite browser, and navigate to http://modduo.local/ (or 192.168.51.1)
- Open your favorite browser, and navigate to http://modduo.local/ (or 192.168.50.1)
Bottom bar
Pedalboard builder
Plugin descriptions
Making/removing connections
- Purple for audio
- Blue for MIDI
- Orange for CV
Setting up actuator mapping
Trigger | Yes | No | Yes |
TODO: explain routine, etc
Saving your pedalboard
Sharing your pedalboard
Using pedalboard presets
Starting from version 1.3, the MOD supports pedalboard presets.
Just like plugin presets, these store the values of all parameters.
On the pedalboard side this means we can store the collective parameter values of all plugins and switch them all at once without having to load a new pedalboard.
The pedalboard preset list can be addressed to a MOD controller knob or footswitch.
There are a few things to consider:
- Pedalboard presets are part of the saved pedalboard state, you need to save the current pedalboard if you wish to retain the presets you made.
- Audio, MIDI and CV connections are not part of the preset data
- If you add plugins after activating pedalboard presets, the existing presets will use the default parameter values for the new plugins
Auto update
Pedalboard library
Creating a new bank
- Press "ADD BANK"
Adding pedalboards
Plugin store
Installing plugins
- Press the "INSTALL" button
Updating plugins
- Press the "UPGRADE" button
Removing plugins
- Press the "REMOVE" button
