MOD Duo User Guide
Headphone jack
The two knobs are used to access and navigate the device menu and tuner. They can also be freely mapped to the parameters of the plugins running inside the MOD Duo, through the WebGUI.
General knob actions
Left knob actions
Right knob actions
General footswitch actions
- width: 160 mm
- length: 186 mm
- height: 75 mm
How to connect an Expression pedal
The MOD Duo does not include a direct port to connect an expression pedal. Yet, there are a few different ways to connect and use a traditional expression pedal with it.
Via Control Chain port
Via MIDI
Other options are MIDI controllers with already built-in expression pedals.
Hooking up the MOD Duo
