MOD Web GUI User Guide
- 1 Accessing the GUI
- 2 Bottom bar
- 3 Pedalboard builder
- 4 Pedalboard library
- 5 Banks
- 6 Plugin store
USB
- Power up the MOD Duo
Bottom bar
Pedalboard builder
Plugin descriptions
Making/removing connections
- Purple for audio
- Blue for MIDI
- Orange for CV
Setting up actuator mapping
| "" | Footswitch | Knob | MIDI Learn |
| Bypass | Yes | No | Yes |
| Toggle | Yes | No | Yes |
| Trigger | Yes | No | Yes |
| List | Yes | Yes | Only for lists with 2 values |
| Value | Only for Tap Tempo | Yes | Yes |
TODO: explain routine, etc
Saving your pedalboard
Sharing your pedalboard
Auto update
Pedalboard library
Creating a new bank
- Press "ADD BANK"
Adding pedalboards
Plugin store
Installing plugins
- Press the "INSTALL" button
Updating plugins
- Press the "UPGRADE" button
Removing plugins
- Press the "REMOVE" button
