Main Page
Documentation
Chapter 1: Device | In this chapter you can find all the information you need about the MOD Duo |
Chapter 2: Web interface | In this chapter we talk about the graphical user interface, accessible through your favorite browser |
Chapter 3: Plugins | This chapter gives information on the plugins that run inside the MOD Duo |
Chapter 4: Warnings | Read this chapter if you want to be on the safe side of using the MOD Duo |
Chapter 5: Resources | This chapter presents a list of resources that we think are worth checking out |
Support
FAQ
A: Connect the MOD Duo to your PC, open your browser and navigate to 192.168.51.1 if connected via USB or 192.168.50.1 if using Bluetooth.
Starting from version 1.2 you can also use modduo.local
Q: Can I hook up USB-MIDI devices?
A: You can hook up external MIDI controllers to the MIDI-IN port or USB-A port. If USB-MIDI is used, the device ports need to be added through the web interface.
Plugin Development
Quick version:
