Main Page
Documentation
Chapter 1: Device | In this chapter you can find all the information you need about the MOD Duo |
Chapter 2: Web interface | In this chapter we talk about the graphical user interface, accessible through your favorite browser |
Chapter 3: Plugins | This chapter gives information on the plugins that run inside the MOD Duo |
Chapter 4: Warnings | Read this chapter if you want to be on the safe side of using the MOD Duo |
Chapter 5: Resources | This chapter presents a list of resources that we think are worth checking out |
Plugin Development
Quick version:
FAQ
A: Connect the MOD Duo to your PC, open your browser and navigate to "192.168.51.1".
Q: Can I hook up USB-MIDI devices?
A: You can hook up external MIDI controllers to the MIDI-IN port or USB-A port. If USB-MIDI is used, the device ports need to be added through the web interface.
Support
