MOD Web GUI User Guide
Example pedalboard of a guitar player: See it in action
Example pedalboard with a MIDI sequencer: See it in action
USB
  1. Power up the MOD Duo
  3. Open your favorite browser, and navigate to 192.168.51.1
  3. Open your favorite browser, and navigate to 192.168.50.1
Bottom bar
Pedalboard builder
The pedalboard builder
Making/removing connections
  • Purple for audio
  • Blue for MIDI
  • Orange for CV
The plugin configuration screen
Setting up actuator mapping
  1. Press the fader icon next to a parameter in the plugin configuration screen
  2. Select an actuator from the drop-down list and press save
  3. If "MIDI Learn" was selected, send the desired MIDI command, it will be detected by the system
  1. Enter the label that you would like to be displayed on the displays of the MOD Duo
  2. Enter the range that you want the mapped actuator to sweep within, inverted ranges are also possible by setting the first parameter higher than the second parameter
  3. Set the sensitivity (amount of steps from minimum to maximum) of the actuator from the dropdown menu
TODO: explain routine, etc
Saving your pedalboard
  • Press the "Save" button for saving to the current pedalboard while keeping the same name
  • Press the "Save as" button for saving the current pedalboard with a different name
Sharing your pedalboard
Auto update
Pedalboard library
The pedalboard library
Screenshot of the banks section
Creating a new bank
  1. Press "ADD BANK"
  2. Enter a name for your new bank
  3. Choose your means of navigation
  4. Add the pedalboards that you want
  5. Put them in the order that you want
Bank navigation
  1. Using the footswitches on the MOD Duo: left footswitch is previous, right footswitch is next pedalboard
  2. Using MIDI program changes: enter the MIDI channel that you want to receive the program changes over. When sending a program change = N message, the Nth board in your bank will be loaded. For example, by sending MIDI program change = 1, the first board in your bank will be loaded.
Adding pedalboards
Plugin store
Screenshot of the plugin store
Installing plugins
  1. Find the plugin you would like to install by browsing through the store
  2. Click on it, a popup will open
  3. Press the "INSTALL" button
  4. The plugin(*) will now be installed
Updating plugins
  1. If an update is available, the plugin label that normally shows "INSTALLED" will change to "NEW VERSION"
  2. Click on the plugin, a popup will open
  3. Press the "UPGRADE" button
  4. The plugin will now be upgraded to the new version
Removing plugins
  1. Click on the plugin that you would like to remove, a popup will open
  2. Press the "REMOVE" button
  3. The plugin(*) will now be removed
Read previous page - Chapter 1: Device
Continue reading - Chapter 3: Plugins
