MOD Web GUI User Guide
USB
- Power up the MOD Duo
Bottom bar
Pedalboard builder
Making/removing connections
- Purple for audio
- Blue for MIDI
- Orange for CV
Setting up actuator mapping
- Select an actuator from the drop-down list and press save
TODO: explain routine, etc
Saving your pedalboard
Sharing your pedalboard
Auto update
Pedalboard library
Creating a new bank
- Press "ADD BANK"
Adding pedalboards
Plugin store
Installing plugins
- Press the "INSTALL" button
Updating plugins
- Press the "UPGRADE" button
Removing plugins
- Press the "REMOVE" button
< Read previous page - Chapter 1: Device Continue reading - Chapter 3: Plugins >
