MOD Web GUI User Guide
USB
- Power up the MOD Duo
Bottom bar
Pedalboard builder
Making/removing connections
- Purple for audio
- Blue for MIDI
- Orange for CV
Setting up actuator mapping
- Select an actuator from the drop-down list and press save
TODO: explain routine, etc
Saving your pedalboard
Sharing your pedalboard
Auto update
Pedalboard library
Creating a new bank
- Press "ADD BANK"
- [Chapter_2:_Web_interface#Bank_navigation Choose your means of navigation]
- [Chapter_2:_Web_interface#Adding_pedalboards Add the pedalboards that you want]
Adding pedalboards
Plugin store
