MOD Web GUI User Guide
TODO: add images of GUI
USB
  1. Power up the MOD Duo
  3. Open your favorite browser, and navigate to 192.168.51.1
  3. Open your favorite browser, and navigate to 192.168.50.1
Bottom bar
Pedalboard builder
The pedalboard builder
Making/removing connections
  • Purple for audio
  • Blue for MIDI
  • Orange for CV
The plugin configuration screen
Setting up actuator mapping
TODO: advanced options
  1. Press the fader icon next to a parameter in the plugin configuration screen
  2. Select an actuator from the drop-down list and press save
  3. If "MIDI Learn" was selected, send the desired MIDI command, it will be detected by the system
Now you can test the actuator mapping. The parameter is now greyed out, and unable to be changed by hand, you have successfully mapped an actuator!
TODO: explain routine, etc
Saving your pedalboard
  • Press the "Save" button for saving to the current pedalboard while keeping the same name
  • Press the "Save as" button for saving the current pedalboard with a different name
Sharing your pedalboard
Auto update
Pedalboard library
This screen will show you all the pedalboards that are currently saved on the device. You are also able to remove the boards that you no longer use from the device by pressing their respective bin icons.
The pedalboard library
Screenshot of the banks section
Creating a new bank
Bank navigation
Adding pedalboards
Plugin store
Screenshot of the plugin store
Installing plugins
Updating plugins
Removing plugins
