MOD Web GUI User Guide
TODO: add images of GUI
USB
  1. Power up the MOD Duo
  3. Open your favorite browser, and navigate to 192.168.51.1
  3. Open your favorite browser, and navigate to 192.168.50.1
Bottom bar
Pedalboard builder
The pedalboard builder
Making/removing connections
  • Purple for audio
  • Blue for MIDI
  • Orange for CV
The plugin configuration screen
Setting up actuator mapping
TODO: advanced options
  1. Press the fader icon next to a parameter in the plugin configuration screen
  2. Select an actuator from the drop-down list and press save
  3. If "MIDI Learn" was selected, send the desired MIDI command, it will be detected by the system
Now you can test the actuator mapping. The parameter is now greyed out, and unable to be changed by hand, you have successfully mapped an actuator!
TODO: explain routine, etc
Saving your pedalboard
Sharing your pedalboard
Auto update
Pedalboard library
Creating a new bank
Bank navigation
Adding pedalboards
Plugin store
Installing plugins
Updating plugins
Removing plugins
