MOD Web GUI User Guide
TODO: add images of GUI
USB
  1. Power up the MOD Duo
  3. Open your favorite browser, and navigate to 192.168.51.1
  3. Open your favorite browser, and navigate to 192.168.50.1
Bottom bar
Pedalboard builder
The pedalboard builder
The top two inputs are the physical audio inputs on your device. The other inputs on the left side are the MIDI devices that you have added, together with the DIN-MIDI in port that is always shown.
Likewise, the top two outputs are the physical audio outputs of your device. The other outputs on the right side are the MIDI devices that you have added, together with the DIN-MIDI out port that is always shown.
Making connections
Setting up actuator mapping
Saving your pedalboard
Sharing your pedalboard
Auto update
Pedalboard library
Creating a new bank
Bank navigation
Adding pedalboards
Plugin store
Installing plugins
Updating plugins
Removing plugins
