MOD Web GUI User Guide
TODO: add images of GUI
USB
- Power up the MOD Duo
Bottom bar
Pedalboard builder
The top two inputs are the physical audio inputs on your device. The other inputs on the left side are the MIDI devices that you have added, together with the DIN-MIDI port that is always shown.
