MOD Web GUI User Guide
TODO: add images of GUI
USB
  1. Power up the MOD Duo
  3. Open your favorite browser, and navigate to 192.168.51.1
  3. Open your favorite browser, and navigate to 192.168.50.1
Bottom bar
  • Keep your system up to date: hover over the rightmost button
Pedalboard builder
Making connections
Setting up actuator mapping
Saving your pedalboard
Sharing your pedalboard
Auto update
Pedalboard library
Creating a new bank
Bank navigation
Adding pedalboards
Plugin store
Installing plugins
Updating plugins
Removing plugins
