Max gen~
Revision as of 11:31, 31 October 2016 by FalkTX (talk | contribs)
Expect some information to be missing.
How it works
Based on that project was made DPF-Max-Gen, which uses the much simpler (and limited) DPF instead of Juce.
DPF-Max-Gen
The most important part is the 'plugins' folder. Inside it there's more folders, each containing a separate plugin (with the exception of 'common', which provides the common/base code for gen~).
  • DistrhoPluginInfo.h
  • DistrhoPluginMaxGen.cpp
  • Makefile
  • gen_exported.cpp
  • gen_exported.h
  • gen~.bitcrush.maxpat
DistrhoPluginInfo.h is a C header file, required by DPF, that describes some plugin meta-data.
This includes name, author, description, LV2 URI and the amount of audio channels.
Modify this file as needed. Remember that LV2 URIs are global and unique, and don't have to be real online URLs.
DistrhoPluginMaxGen.cpp is a symlink to the real DistrhoPluginMaxGen.cpp file located in the common folder.
This symlink is here so that we compile a different instance per plugin, but the actual code is the same.
Do not modify this file.
Makefile contains the build rules for compiling the plugin.
The only thing that needs change here is the 'NAME' parameter, which specifies the target LV2 bundle and binary name for the plugin.
You should get a few more files when exporting code, but only these 2 matter.
Compiling
Native
Before trying to build the plugins for MOD, it's a good idea to see if they work locally on your own PC first.
After you git-clone the DPF-Max-Gen project (recursively, it has submodules), you can just do:
$ cd DPF-Max-Gen $ make
If you're running Mac OS use 'make MACOS=true'.
After it finishes you'll have LV2 and VST2 plugins inside the bin folder.
See if they work on your favourite host. :)
MOD
See How_To_Build_and_Deploy_LV2_Plugin_to_MOD_Duo for more details.
Making your own plugins
Right now we do not have the process of turning the gen~ exported code into a plugin directly. You'll have to do some manual work.
A good starting point might be to just fork the DPF-Max-Gen project and use it to start your own.
The 'Makefile' file in the root folder contains the list of plugins to build, which reside in the plugins folder.
If you've handled makefiles before it should be pretty straight forward.
If not please contact us for ideas and discussion on how to possibly automate the creation of this type of plugin.
