Max gen~
Apart from programming LV2-plugins in a "traditional" way, it's also possible to generate LV2-plugins for MOD devices from gen~ objects created in Cycling '74 Max.
Gen basics
Designing your effect in Gen
Getting your Gen-based plugin to a MOD device
At this point you should have met the requirements specified above. If so, follow the steps below to get your plugin on a MOD device.
In order to run Gen-based plugins on a MOD device they must be converted into LV2 plugins and compiled using a custom MOD cloud build system.
Your plugin will now be transferred to the MOD device, within a few minutes the MODwatcher will tell you if the upload succeeded.
On a Mac you can do this with the nano editor:
Video tuto here : https://www.youtube.com/watch?v=CaLKImvc11w
- Open up Terminal
- Enter
$ ssh root@192.168.51.1
- Password
$ mod
- Enter
$ .lv2/YOURPLUGIN_NAME.lv2/YOURPLUGIN_NAME_dsp.ttl
i.e. to get a switch for this parameter:
a lv2:InputPort ,
lv2:ControlPort ;
lv2:index 5 ;
lv2:symbol “FILTER” ;
lv2:name “FILTER” ;
lv2:default 0 ;
lv2:minimum 0 ;
lv2:maximum 1 ;
which gives:
a lv2:InputPort ,
lv2:ControlPort ;
lv2:index 5 ;
lv2:name “FILTER” ;
lv2:default 0 ;
lv2:minimum 0 ;
lv2:maximum 1 ;
i.e if you want the host/mod tempo to control a time parameter
@prefix time: <http://lv2plug.in/ns/ext/time#> .
lv2:ControlPort ;
lv2:index 2 ;
lv2:symbol "BPM" ;
lv2:name "BPM" ;
lv2:default 120 ;
lv2:minimum 24 ;
lv2:maximum 280 ;
units:unit units:bpm ;
lv2:portProperty mod:tempoRelatedDynamicScalePoints;
i.e if you want a selector
@prefix rdf: <http://www.w3.org/1999/02/22-rdf-syntax-ns#> .
And change i.e. this:
a lv2:InputPort, lv2:ControlPort ;
lv2:index 6 ;
lv2:name "Div_L" ;
lv2:symbol "Div_L" ;
lv2:default 1.000000 ;
lv2:minimum 1.000000 ;
lv2:maximum 5.000000 ;
To this :
lv2:index 6 ;
lv2:name "Div" ;
lv2:symbol "Div" ;
lv2:default 1.0 ;
lv2:minimum 1.0 ;
lv2:maximum 5.0 ;
lv2:portProperty lv2:integer;
lv2:portProperty lv2:enumeration ;
lv2:scalePoint [rdfs:label "1/4note"; rdf:value 1];
lv2:scalePoint [rdfs:label "Dotted1/8note"; rdf:value 2];
lv2:scalePoint [rdfs:label "1/4notetriplets"; rdf:value 3];
lv2:scalePoint [rdfs:label "1/8note"; rdf:value 4];
lv2:scalePoint [rdfs:label "1/8notetriplets"; rdf:value 5];
Ctrl + x
- select Y(yes) or N (no)
- Enter
systemctl restart mod-ui
- Enter
exit
- CAUTION: Delete your cache Browser to be shure to see the changes on your GUI
If all goes well, your modified Gen-based plugin should now be inside the MOD device, ready to be played!
Alternatively
There is another process which is different from the process described above. It doesn't use the MOD Duo-package in Max.
Compiling the plugin
First, download https://download.moddevices.com/releases/max-gen/max-gen-deploy_v6.tar.gz and extract it.
Send an "exportcode" message to the gen~ object in your main Max-patcher to get the YOURPLUGIN_NAME.cpp and YOURPLUGIN_NAME.h files.
replace YOURPLUGIN_NAME with “gen_exported" for both files
$ cd /path/to/max-gen-deploy/
$ ./mod-build.sh
Editing the plugin
OPTIONAL
$ tar -xzvf Plugin.lv2-dwarf.tar.gz
$ rm Plugin.lv2-dwarf.tar.gz
Deploying the plugin
$ ./mod-deploy.sh
