Open Images
This page contains links to the latest unencrypted "open" MOD OS images.
They can be extracted and repackaged for a "custom ROM" style approach.
Installation of these images requires the MOD unit to be running v1.13.5 or later.
There is no support from MOD Audio for these images
Make sure to backup your unit before trying any custom changes.
If you get into troubles you can always reinstall from scratch, see the per-device reinstall steps at the bottom of Troubleshooting_Reinstall#MOD_does_not_boot_at_all.2C_not_even_in_restore_mode.
MOD Duo X limited edition units cannot be reinstalled this way, there is a real risk of bricking the older Duo X units!
Release links
MOD Duo: modduo-v1.13.5.3317.tar
MOD Duo X: modduox-v1.13.5.3316.tar
MOD Dwarf: moddwarf-v1.13.5.3315.tar
Packaging notes
  • Compatible binaries can be built using mod-plugin-builder
  • Custom device controller firmware can be built from these repos for MOD Duo, MOD Duo X and MOD Dwarf
  • The SHA1SUMS file needs to be updated to match an updated system.tar.xz
  • Instructions on how to build your own Linux kernel coming soon
Known alternative images
