MOD SDK
The SDK
MOD SDK screenshot
The SDK Wizard
  • Allows developers test the plugin's GUI
  • A wizard to easily create a plugin GUI without the need to write any line of code, simply choosing from templates.
  • Deploy plugins into your MOD
Running the SDK
The easiest way to run the MOD SDK is to use its Docker image. This way you dont have to install anything special and bother with complicated environment settings. Simply install docker and run the provided image.
If you don't want to use docker, visit MOD SDK's github page and follow the instructions there on how to install it.
Running the SDK on Windows
2. Choose a folder where you will store your LV2 plugins bundles. In this folder place all the bundles you want to test with the SDK
3. Pull the SDK image from Docker Hub.
Open the Command prompt and type
docker pull moddevices/modsdk
You only need to run this command the first time. It will download the image and store it locally.
4. Once the download is completed, run the following command, replacing the path with the path of the folder where you are storing your LV2 bundles.
docker run -p 9000:9000 -v /c/Users/my-user/my-lv2-folder:/lv2 moddevices/modsdk
In the command above, my chosen folder is C:\Users\my-user\my-lv2-folder. When you run this command, Windows will ask if you give permission to share this folder with Docker. Accept it and continue.
The MODSDK assumes your LV2 plugin resides in a Windows directory. To create any such LV2 plugin, you need to compile your code using the Mod Plugin Builder (MPB) in Docker. When running the MPB you have to use the -v option. $ docker run -ti –name mpb -p 9000:9000 -v ~/local-mod-folder:/tmp/local-mod-folder This creates in Windows a folder “local-mod-folder” under /c/Users/Username/. And in Docker a folder /tmp/local-mod-folder/. These two folders now share the same content. When you compile as per instruction, the lv2 plugin resides in docker in ~/mod-workdir/plugins/. You now have to copy it to the shared drive using cp -r ~/mod-workdir/plugins/ /tmp/local-mod-folder/. You can now see your compiled LV2 plugin under Windows in the folder /c/Users//Username/local-mod-folder/plugins/. When running the MODSDK you have to use -v and state /c/Users//Username/local-mod-folder/plugins:lv2 so that the MODSDK looks in that folder for LV2 plugins.
5. Now open your browser and visit localhost:9000 In some instances your browser will not be able to connect using localhost:9000. In these instance you have to connect using Machine-IP:9000 instead in your browser command line. Your machine IP is visible once you start Docker. It consists of numbers in the following format: xxx.xxx.xx.xxx
Running the SDK on Linux
Once docker is installed, pull and run the image:
docker run -p 9000:9000 -v /home/my-user/my-lv2-folder:/lv2 moddevices/modsdk
Running the SDK on Mac
1. Install Docker for Mac. It is as simple as installing any other application.
docker run -p 9000:9000 -v /Users/my-user/my-lv2-folder:/lv2 moddevices/modsdk
Building the SDK
